Problem while start ProTK dll on another PC
Eike_Hauptmann
I have written a small tool in Visual Studio 2005 for Wildfire 4. On my pc it work like a charme. On the other pc (also Windows 7 Professional 64 bit, Wildfire 4 M200 - 64 bit, same Hardware) it don't work. The only Failure I get is that Pro Engineer can't start the Application. (it is not the "file not found" error) The other PC has no Visual Studio 2005 installed.
The other PC has a Pro Toolkit License too. I have installed the Visual Studio 2005 redistributable package (64bit). Nothing happens. Have anyone an idea what I can do to solve this problem?
Best regards,
Eike
6 REPLIES 6
In Reply to Eike Petersen:
Best regards,
Eike
And what's the exact error message, you get?
Regards, Domenic
Thx to Ronald Tellen who has written me an E-Mail :
shortened Content : Try to install .Net 2.0
I have installed it and it didn't helped, but thx for the answer.
With a DLL - Dependency Walker I get on the PC on that it isn't work (Side by Side configuration error)
To Domenic:
The complete Failure is in german, because my Wildfire version is in german, I try to translate it:
The ProToolkit program "Model Processor" can't be started. Please look inside the Trailfie to get more informations.
After click ok in this window a second one appear.
Inside the Trailfile only the Failure message appears a second time.
Best regards,
Eike
Are you sure your exec_file and text_dir lines in the protk.dat file are correct?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image001.jpg@01CD7083.633B9BD0]
Hi Eike,
Be sure to compile your executable in Release mode. If it is compiled in
Debug mode, it will expect the full MS VS Debugger to be available and I
would expect the exact error you are seeing.
Ben
I'm German speaking too. 🙂
Back to the problem ... because you're using Windows 7 x64, I assume, you've installed the Service Pack 1 of Visual C++ 2005?! Otherwise Visual C++ won't run.
If you look at the platform notes of Pro/TOOLKIT for Pro/E Wildfire 4.0 (http://www.ptc.com/WCMS/files/53026/en/ProTOOLKITPlatformsWildfire40.pdf) you'll see that SP1 is not supported for the 64-bit platform. This is because of a bug in Visual C++ 2005 SP1.
When we migrated to Windows 7, we installed Visual C++ 2008 as development environment. And till now we haven't had any problems with it.
Regards, Domenic
Thx at all for helping.
I found a solution for my problem.
My DLL was Mutli threaded DLL (in Properties -> C / C++ -> General) and I changed it to Multi Threaded.
After that I need to let the Linker know (Properties -> Linker -> Input -> Ignore Specific Library = libcmt.lib)
After that my build dll don't need other DLLs and I don't have the problem I've had before.
Best regards,
Eike
