Creo Agent Issue on Windows 7 32 bit
All,
I'm getting a problem on Windows 7 Pro 32 bit machines and installing Creo Parametric 2.0
Creo installs fine and then on launch it installs pvx and the Creo Agent 2.9, the I see a message dialogue saying that "Creo 2.0 from PTC has stopped Working" You can cancel this error message and Creo runs fine.
I contacted PTC Tech Support who are looking into this and from them they suggested to uninstall the creoagent and change the name of the installer file in <CREO_INSTALL>\Common Files\M010\install\addoncreoagent_32.msi to .old This will stop Creo from being able to install the agent,
This is fine accept that it stops things like the learning connector working
Looking at the Windows Event logs I see the error pointing to KERNELBASE.dll
Anyone got any ideas as to what is causing this
I've tried re-installing creo several times and ensuring there are no creo reg entries or files left anywhere on teh machine
I also found another log file showing an error
So I am now stumped as to what is the real issue. Any one seen this or can help it would be really useful if they could let me know what they did or how far they got with it
