I need to remove all unused drawing models.
And I don't know if this is possible to do it with a macro or something like that.
can help me somebody?
Thank you,
Alberto Todisco
Can you explain me the process?
you need to set UNUSED_MODELS check to Y or E in your .mch file.
This works only if you have enabled ModelCHECK.
Hi Alberto
If you don't use Modelcheck, but you are working with Windchill, you could use this creo config option:
cleanup_drawing_dependencies=yes_cs_not_required
More info in this Article
Hi Trebla,
that's the better solution!! thank you so much
Seems this config option is not available in Creo 5, at least to me.
Has anybody haved similar problem in Creo 5 (with unused models and lack of cleanup option in config.pro)?
Hi Jacek_Mydlikows,
I work with creo4, so I can not check in creo5.
In Olaf Corten's web it appears as an option also in creo5.
You have to add inside your config.pro:
cleanup_drawing_dependencies yes_cs_not_required
I don't think that is going to do what you want. All the does is remove the reference. Not the actual model.
Did you test it? I don't think it removes that actual model from the drawing. I believe it removes only the REFERENCE link to a model.
Hi Steve, yes I tested, It removes all 'unused drawing models' not the actual model.
To remove the 'unused drawing models' is what Alberto_Todisco was asking for.
Yes, you only erase the missing dependents references, but that was the aim.
best wishes
# p-Shell # „ps_draw delete“ will return 1 on success and 0 if fail
# if your case you may not interested
# and the code is ignoring the return value
# sample A
# if your active window contains a Drawing
foreach M [ps_draw list] {ps_draw -mod $M del }
# sample B
# # for all drawings in session
foreach D [ps_glob *.drw] { foreach M [ps_draw -draw $D list] {
ps_draw -draw $D -model $M delete
# sample c
# # for test.drw
# foreach M [ps_draw -draw test.drw list] {
ps_draw -mod $M -draw test.drw delete
please provide more information about p-Shell.
Link to p-Shell Wiki, and there a YouTube Link. Its a Toolkit Application, which allows you to access Creo Files and their Database via Tcl (Script Language) commands within a running Tcl/Tk environment. On the Wiki you find a lot of code snippets. You are ready with your first program in p-Shell, before you would have setup Toolkit and the compiler on the other hand ![]()
