Release Notes for Parametric
OS_11014878
Hello, where can i find the release notes just for parametric.
For example, i have 10.0.3.0 and i want to see whats have changed in 10.0.6.0 or 11.0.2.0?
In search i could find it just for toolkits...
mkajdan
(To:OS_11014878)
I think Update Advisor is what you might be looking for to see bug fixes.
10 REPLIES 10
To be honest, I've never seen such a thing. With non-commercial or more "open" software packages, when a new release is put out into the world, it is often accompanied by a list of new features, list of bugs fixed, etc. For PTC, it seems all one has to go by is press releases, videos talking about "What's New in Creo X", etc. I've never seen a detailed document indicating what new features have been added, etc.
Dale_Rosema
(To:OS_11014878)
Login in to PTC.com
https://www.ptc.com/en/support
Click "What's New" on the bottom of the right hand side.
It brings you to the "What's New Tool" where you will fill in the boxes:
Dale_Rosema
(To:Dale_Rosema)
The at the bottom of the tool are pages for the additional releases if you type in 11.0.2.0 instead.
That's an interesting thing. Wish it would show a direct comparison rather than all the intermediate ones.
Dale_Rosema
(To:KenFarley)
It's probably the easiest way to program it for the web.
Each chunk will always be the same for the incremental jumps.
Thanks, but it seems strange to me that the Version 10.0.4/5 should be the same as 10.0.3.0.
It´s just about the features but not the bugfixes.
Guess there is no list about the bugfixes?
mkajdan
(To:OS_11014878)
RPN
(To:OS_11014878)
Check the Tookit folder, here is a pdf mentioning each change, release by release.
thanks you very much.
