Session::GetCurrentModel method throws exception.
Harsh9592
7-Bedrock
Hi All,
I start learning Creo customization using Jlink.
I start learning with getting the name of the current model in session but it can't work.
here is mode code.
can somebody help me where am I making the mistake?
import com.ptc.cipjava.jxthrowable;
import com.ptc.pfc.pfcAsyncConnection.AsyncConnection;
import com.ptc.pfc.pfcAsyncConnection.pfcAsyncConnection;
import com.ptc.pfc.pfcModel.Model;
import com.ptc.pfc.pfcSession.Session;
public class AsyncTest {
	AsyncConnection conn = null;
	Session session = null;
	Model model = null;
	public static void main(String[] args) throws jxthrowable, Exception {
		// TODO Auto-generated method stub
		System.loadLibrary("pfcasyncmt");
		AsyncTest tt = new AsyncTest();
		tt.runCreo();
	public void runCreo() throws jxthrowable {
		try {
			conn = pfcAsyncConnection.AsyncConnection_Connect(null, null, null, null);
			Thread.sleep(5000);
			session = conn.GetSession();
			model = session.GetCurrentModel();
			System.out.println(model.GetFileName());
			conn.Disconnect(null);
		} catch (Exception ex) {
			System.out.println(ex.getMessage());
			if (conn.IsRunning()) {
"conn.GetSession();" return 'Null' value.
I don't know why this happening.
Thanks in advance!!
remy
(To:Harsh9592)
try:
conn = pfcAsyncConnection.AsyncConnection_Connect("", "", "", 10);
if this still does not fix your issue, you may file a case.
