Usage of ActionListener - C++ Toolkit
michi
Hi everybody,
I'm new at this topic, so this is some newbie question. I want to know, how to use Actionlisteners. So i added a same example. There is a tester-class and beneath user_initialize(){} is the OnAfterModelDisplay methode. In user_initialize() i tried different things to get any respone in Creo. I thought i have to take something like the pointer wSession and call addactionlistener with a smartpointer to a Listener (what ever a listener is?!). But nothing worked.
The same problem i have with the other Actionlisteners, which need a methode-call addactionlistner.
Can somebody help me at this point and show me the right direction please. i really want to understand the whole concept of this. thank you!
<inculdes>
class tester : public pfcSessionActionListener
public:
	tester(){} //default constructor
	void OnAfterModelDisplay();
extern "C" int user_initialize(
	int argc,
	char *argv[],
	char *version,
	char *build,
	wchar_t errbuf[80])
	try
		pfcSession_ptr Session = pfcGetProESession ();
		wfcWSession_ptr wSession = wfcWSession::cast (Session);
		wSession->AddActionListener(smartpointer to Listener );
		return (wfcTK_NO_ERROR);
void tester::OnAfterModelDisplay()
	try
        //do something great
FV
(To:michi)
tester class should be extending pfcDefaultSessionActionListener (#include "pfcSession.h").
Otherwise you'll have to implement all methods even unused ones because pfcSessionActionListener class contains only pure virtual methods  - this is C++ , nothing to do with OTK.
Pure virtual method :
      virtual void Foo() = 0;
is not an empty function (method) :
     virtual void Foo() {;}
HIH.
FV.
@michi wrote:
Thank you for your answer!
The thing is, that i can't use
pfcActionListener_ptr listener = new tester();
because visual studio throws an error: "the class is abstract"
My understanding was, that the class pfcSessionActionLIstner is an abstract class and it has all actionlistner methods declared as empty functions. Then a user-defined subclass (tester) is defined and inherits everything from "pSAL" and i overload the methods i need in this new class. So my class shouldn't be abstract anymore...
So now i don't know, what i have to do, to get an user-defined class, that's not abstract 😄 Do you see any mistake i make or what thing i didn't understand?
oh and thanks for the information about the xobject. Really appreciate that sort of tips and hints!
FV
(To:michi)
First of all, you should not use smart pointers with pfcActionListener otherwise you are for a number of unpleasant surprises. pfcActionListener is inheriting from xobject which is a reference counting 'thingy' from 1990's...
The calling code should be modified like this:
instead of:
should be:
wSession->AddActionListener(listener);
The cleaner approach would be to define pfcActionListener variable as static/global outside of user_initialize(). This would allow to call  something like this from user_terminate():
wSession->RemoveActionListener( g_LISTENER)
g_LISTENER = NULL;
HIH.
FV.
@michi wrote:
Hi everybody,
<inculdes>
public:
	int argc,
	char *argv[],
	char *version,
	char *build,
	wchar_t errbuf[80])
	try
	try
michi
(To:FV)
FV
(To:michi)
HIH.
FV.
michi
(To:FV)
Thank you very much! learned a lot.everything works great.
After testing i read the user guide again. Now i get it. The pfcactionlistner (of course the one i want to use) class is the base class and there is also a pfcdefaultactionlistner class, which sub-classes the pfcactionlistner-base-class. and in this class there are all methodes implemented emtpy. So i don't have to do that in my code.
