Using the VBAPI to create a drawing with a template, getting err pfcExceptions::XToolkitNotFound
chshasa1
hi All
i acutally have the same issue as this post here:
https://community.ptc.com/t5/Customization/Using-the-VB-API-to-create-a-drawing-with-a-custom-template/td-p/17502
but the possibilities to fix mentioned there do not work for me, does anyone has an idea?
i am using creo 7.0.12.0
Feel the magic
chshasa1
(To:Catalina)
hi all
sorry for the late reply.
had contact with ptc support. they suggest using the run.macro functionality to run a mapkey recoreded before and then adding there the variables.
Feel the magic
Hi @chshasa1,
Thank you for your question!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi Catalina,
in such cases, it would be a good idea to explain to the questioner how he can contact PTC Support.
Martin Hanák
please ask PTC Support.
Martin Hanák
Hi @chshasa1,
You can contact PTC Support by opening a case here: https://www.ptc.com/en/support/case-logger?destination=https://support.ptc.com%2Fapps%2Fcase_logger_viewer%2Fcs%2Fauth%2Fssl%2Flog%3F&msg=1.
Thanks for using the Community!
Best regards,
Catalina
PTC
chshasa1
(To:Catalina)
hi all
Feel the magic
