hi All
i acutally have the same issue as this post here:
but the possibilities to fix mentioned there do not work for me, does anyone has an idea?
i am using creo 7.0.12.0
hi all
sorry for the late reply.
had contact with ptc support. they suggest using the run.macro functionality to run a mapkey recoreded before and then adding there the variables.
Hi @chshasa1,
Thank you for your question!
Best regards,
Hi Catalina,
in such cases, it would be a good idea to explain to the questioner how he can contact PTC Support.
please ask PTC Support.
Hi @chshasa1,
You can contact PTC Support by opening a case here: https://www.ptc.com/en/support/case-logger?destination=https://support.ptc.com%2Fapps%2Fcase_logger_viewer%2Fcs%2Fauth%2Fssl%2Flog%3F&msg=1.
Thanks for using the Community!
Best regards,
hi all
