Visual Studio 2010 Express
pwilliams-3
Has anyone been able to get the property sheets (contains the compiler and linker settings) to appear once the x64 platform has been added to the solution? I think this also happens in the Professional version. How did you fix it?
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image003.jpg@01CC9AF2.B4D03990]
Hi Patrick,
I have the 2010 Professional and everything works correct with the property pages. I never had problems with the pages and can build for 32 and 64 bit. I build with the Creo 1.0 Sources, but don't think that it is different to other ones at property pages.
Best Regards,
Eike
I found the answer. I had to repair the Windows SDK 7.1 installation and then the property pages showed up. Here's another question though. When compiling the Debug configuration I am now receiving an _ITERATION_DEBUG_LEVEL mismatch error. Have you ever received that error and how did you fix it?
[cid:image001.jpg@01CC9D1E.4A145D10]
