Window not closing using VB API
TusharSuradkar
with the VB API on Creo 5
I am using model.Erase()
followed by
window.Close()
But the window remains open, though the model is erased.
Is there a solution for this?
Q: What is the equivalent API for 'Erase not Displayed'?
I also tried window.Clear()
but that was of no use.
~Tushar
As said in documentation:
If the model is displayed in a window, the model is marked to be erased when control returns the Creo Parametric UI from the application. It is not erased immediately.
So window need to be closed first.
That worked like a charm.
Thanks a lot @sjuraj.
~Tushar
