Window not closing using VB API
  • October 16, 2022
  • 2925 views
with the VB API on Creo 5
I am using model.Erase()
followed by
window.Close()
But the window remains open, though the model is erased.
Is there a solution for this?
Q: What is the equivalent API for 'Erase not Displayed'?
I also tried window.Clear()
but that was of no use.
~Tushar
Best answer by sjuraj
As said in documentation:
If the model is displayed in a window, the model is marked to be erased when control returns the Creo Parametric UI from the application. It is not erased immediately.
So window need to be closed first.
sjuraj15-MoonstoneAnswer
That worked like a charm.
Thanks a lot @sjuraj.
~Tushar
