distributed bach problem
Hi folks,
I have tedious assignment of removing pro/program INPUT parameters (all lines betwee INPUT and ENDINPUT commands in pro/program). In order to make this process easier I created simple vbs script which removes this redundant lines automatically. Then I've changed pro_editor_command option to "cscript c:\script.vbs" so when I choose Pro/Program -> Edit Design it returns cleaned pro/program. Next I recorded mapkey:
mapkey pp ~ Activate `main_dlg_cur`;\
mapkey(continued) ~ Command `ProCmdMmProgram`;\
mapkey(continued) #EDIT DESIGN;Yes;#DONE/RETURN;\
mapkey(continued) ~ Command `ProCmdModelSave` ;~ Activate `file_saveas` `OK`;
so far so good.
But when I run this mapkey from Creo Distributed Batch it just isn't working (CDB stays on "working" mode - I waited 2 hours and still the same). What am I doing wrong? Or mayby someone have another idea how to deal with such task.
Thanks in advance
Pawel
