how to create a gtol in drawing mode?
can anyone help? or share some codes?
i did it with protoolkit, however, it does not work right. Maybe the annotation plane or the placement is set wrong.
procedure is as follows,
check ProGtoldataStatus step by step,
it's a little complex, the reference , the model, the type and the placement have relations to each other.
ProGtoldataAlloc(drawing,>d);
ProGtoldataModelSet(gtd,solid,>ds);
ProGtoldataTypeSet(gtd,type,>ds);
ProGtoldataReferenceSet(gtd,rtype,reference,>ds);
ProGtoldataPlacementSet(gtd,ptype,NULL,NULL,location,NULL,>ds);
ProGtoldataPlaneSet(gtd,&plane);
ProGtoldataGtoldatumrefSet(gtd,NULL,NULL,NULL,>ds);
ProGtoldataDiameterSet(gtd,diameter,>ds);
ProGtoldataValueSet(gtd,b_v,d_v,name,>ds);
ProGtoldataMatCondSet(gtd,matcond,>ds);
ProGtolCreate(gtd,>ol);
ProGtoldataFree(>d);
