is it possible a creaet Drawing with toolikt?
CHASEONHO
18-Opal
Hi
is it possible to creaet a Drawing with toolkit?
if select a specific model, we get model name using ProMdlNameGet.
and model name will be fill a New Drawing File name.
and call dialog following picture.
is it possible?
and can toolkit call a update sheets?
thanks
Below is list of API:
  • ProDrawingFromTmpltCreate() to create drawing from template
  • ProDwgSheetRegenerate() for sheet update. Make sure you set all drawing sheet as current sheet one by one before calling API ProDwgSheetRegenerate().
- HIH
Ketan
- HIH
Ketan
Thank you!
also you can call new drawing dialog with using ProMacroLoad()
Yes...But I personally dont prefer macro. I try to avoid it as much as possible.
why are you avoid using macro?
can you tell me?
There are certain limitations and expectations for the same. Please go through API description for both the API ProMacroLoad() and ProMacroExecute().
