pfcExceptions::XToolkitCantModify error while running vbapi application
Prasad_G
11-Garnet
I am getting "pfcExceptions::XToolkitCantModify" error while running a vbapi CREO automation application which I have developed for CREO 2.0. The application works fine in my system but throws this exception when I try to run in other user's system.
PS: I  have already ensured the following things:
1) checked that the environment variable PRO_COMM_MSG_EXE is set to right path
2) vb_api_register.bat is run and the  COM server is registered
Is there anything else that can cause this issue?
Any help would be appreciated
Thanks and Regards,
Prasad
Prasad_G
11-Garnet
(To:remy)
Hi Remy,
Thanks a lot for reply.
If anyone is facing a similar issue, they can build the designated CREO vbapi application in different build .net frameworks or update the .net framework on the system.
Prasad
remy
(To:Prasad_G)
Hi
First Creo 2. is not supported anymore.
Nonetheless when searching the knowledge base you can find this article : https://www.ptc.com/en/support/article/cs352808 that recommends to update the .Net Framework on the client workstation.
Did you try it?
Prasad_G
11-Garnet
(To:remy)
Hi Remy,
Prasad
