Hello
We need to do automation of Optimization study. Can we run optimization using toolkit? If yes, please help me with some input.
If it is not possible through toolkit, please do share if it is possible using VBAPI or granite as well. Thanks a lot in advance!
Ketan
Is there anything we can do through customization?
You create test case by running manually for say 100 files. Use that trial file to run next time. This is how automated tests are achieved in Creo.
I am not sure is there any other way.
Suresh
Could not get you what you want to convey. Cannot create test cases manually for optimization as scenarios changes from input to input. That is why optimization is there.
Please elaborate more so that I can link with current scope.
