To all
I am trying to learn CREO customisation so I am "playing" around with mapkey + .vb file.
I set up a mapkey 'OS Script' option pointing to a .vb file containing a simple test program. If I press 'run' I can see the command DOS window being open but then I get a request to select the app (windows 10) to run the .vb file. So far I have not found anything in the vbapi doc on the matter. How does one run any of the vbapi examples provided?
@JBlackhole wrote:
To all
please upload your simple test .vb program and describe its functionality.
... and tell us installed Creo version.
Creo 5
Any program will do. Maybe the standard "Hello World" either displayed to a msgbox or in the status bar
something like that?
Public Class test1
Public Sub mytest1
Dim TheSession As pfcls.IpfcSession
Dim message As Istringseq
message = New Cstringseq
message.Set(0, "Hello World")
TheSession.UIDisplayMessage("Title", "a message", message)
Msgbox("Hello World")
End Class
@JBlackhole wrote:
Creo 5
Public Class test1 Public Sub mytest1 Dim TheSession As pfcls.IpfcSession Dim message As Istringseq message = New Cstringseq message.Set(0, "Hello World") TheSession.UIDisplayMessage("Title", "a message", message) Msgbox("Hello World") End Class
in attached document you will find decription of procedure I just finished. It may help you understand how Creo VBAPI works.
Thanks for the info. I think I have read some of it (in the manual) (PRO_COM_MSG_EXE, etc) . Just haven't tested from xls as my attempt is to see if I can run a .vb file as-is. Having said that I will have ago at the test macro provided
