window created by ProObjectWindowCreate has no ribbon and can't be closed.
jzhang-6
hello all,
I recently made a dll with toolkit. I want to open 2 models at the same time, and I used the codes like this:
ProObjectwindowCreate( mdl_name, mdl_type, &w_id);
ProWindowActivate( w_id);
But the created window has no ribbon and can't be closed.
Does anyone know why?
Thanks in advance.
FV
(To:jzhang-6)
You'll need to use ProWindowCurrentSet instead of ProWindowActivate
This sequence works from WF5 to Creo 3 (WF3 and WF4 would need a different one)
ProObjectWindowCreate(...);
ProWindowCurrentSet(...)
ProMdlDisplay(...)
FV
(To:jzhang-6)
ProMdlDisplay(...)
jzhang-6
(To:FV)
OK, thank your for you answer, .
I will try these codes this evening.
