Hello!
I Downloaded Creo for school use. I have a problem at installation. The installer stops working at the step where it verifies the licence. I downloaded Creo 3.0 64bit version. I have Windows 10. I tried running as admin and in compatibility mode. This problem is not only on my PC. I have several friends that have the same problem.
Thanks in advanced for any help!
what is the size of downloaded file ? Did you unzip it ?
MH
The size of the downloaded zip file is 3.82GB. I unzipped it and in the folder there are 3 exes: setup; setup-schools; setup-trial. I ran the installer setup-schools and I get to this screen with "Please wait while we retrieve your licence" and then it just stops working. The only solution is to force close the setup.
Your problem can be related to network card MAC address. Maybe installation is not able to get your network card MAC address.
I can check network card status for you, if you publish contents of ip.txt file created by following command entered in DOS prompt window.
ipconfig /all > ip.txt
Also check what files are save in C:\ProgramData\PTC\Licensing directory.
MH
Hello! Sorry for responding so late. In ProgramData I don`t have any PTC folder...
Here is the content of the ip.txt file.
Windows IP Configuration
Host Name . . . . . . . . . . . . : DIMI-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection I217-V
Physical Address. . . . . . . . . : 54-BE-F7-0B-8F-3A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::846d:cd6b:bb69:48dc%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Thursday, November 10, 2016 2:09:26 PM
Lease Expires . . . . . . . . . . : Monday, December 18, 2152 11:54:45 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 55885559
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1F-90-3A-AF-54-BE-F7-0B-8F-3A
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{FE7D1858-7AEA-4E94-95EF-65C29261E7DF}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:2cfb:bdfe:adb2:5e37(Preferred)
Link-local IPv6 Address . . . . . : fe80::2cfb:bdfe:adb2:5e37%4(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 67108864
NetBIOS over Tcpip. . . . . . . . : Disabled
Hope you can help me!
