Can you have multiple drawing views each with its own simplified rep all derive the balloons from one table?
Hi Todd,
No, this is not possible. The drawing view, repeat region table and BOM balloons are all connected and parametric.
The BOM balloons will show on the drawing view, based on the information from the repeat region table. If the information on the repeat region table is modified, the balloons will update.
You need one table for each view, to show the BOM balloons.
Amit
Yes it is possible but it is not supported.
See here:
Allow BOM Ballons from Master Rep Repeat Region to be displayed on Simplified Reps
Chris,
Does this still work in Creo 3?
Oh wait, there it goes. Menu manager was popping up behind.
Amit
Can please you clearify why this is not possible?, this is way we typically create a detail view of a single component within an assemly drawing; with balloon.
