I am new with Creo Schematic and I am trying to understand how to resolve the relantionship between 2 diferent drawings that share information about components.
For example, I have a schematic drawing that represent the logic funtional of something but also I have another drawing of the fisical representation of the schematic (panel drawing).
What I want to know if is possible get automatic updates of the properties components (like manufacturer or catalog ID) in the Panel Drawing when I change the same information in the same component but in the schematic Drawing in a diferent file.
I will appreciate very much your feedback.
The way we have setup our Schematic library is to have datatables with the parametric data associated to the block. If that information changes for a part, we update the datatable then you have to update that instance in each drawing/schematic that uses the part. There is no automatic update.
