We've added a Waterfall Chart Widget to the Mashup, but we still need to bring in backend data.
With the Waterfall Chart bound to data, we now just need to configure a few of the chart's Properties.
Up to this point, we've created a Data Shape to format the columns of an Info Table Property. You then created a Thing, as well as an Info Table Property formatted by the Data Shape. As a test, you added some manually-entered data to the Info Table. After creating a Mashup, you added a Waterfall Chart Widget and tied it to that backend data.
The only thing left to do is to visualize your GUI.
The end result is a visualization of burn up/down as the project is first defined and then implemented.
Congratulations! You've successfully completed the Track Progress with Waterfall Chart guide, and learned how to:
We recommend the following resources to continue your learning experience:
| Capability | Guide |
| Manage | How to Display Data in Charts |
If you have questions, issues, or need additional information, refer to:
| Resource | Link |
| Community | Developer Community Forum |
| Support | Waterfall Chart Help |
