1. What problem are you trying to solve?
I have an application and i can send data using HTTP connector. How to add that HTTP connector in kepware?. If i change some data in application and send it through connector it need to be reflected in kepware.
2. Are you using a workaround?
Kepware
3. What is the use case for your organization?
Connection of app to kepware
4. What impact does this problem currently have on your organization?
We are able to get the data but need to know how we can send the data or change the data.
Thank you @HV_12857899 for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
Hi @HV_12857899! It sounds like you're asking for assistance configuring this connection rather than suggesting a new idea. If that is the case - we do have a customizable driver that can be built to interact with some HTTP interfaces. There is sample code for this driver available here: Universal-Device-Driver-Examples/HTTP-REST at main · PTCInc/Universal-Device-Driver-Examples · GitHub. There are some limitations with this driver, including no support for TLS/SSL. If you need further assistance configuring this connection, the Kepware Discussion board would be better suited for this topic. If I've misunderstood and you are suggesting a new idea, can you provide some more detail around what is needed that is not current functionality?
Sorry for that its a question. How we can add HTTP connector in Kepware? To run that what are the things we need to have?
