HTTPS configuration for REST SERVER
VS_12009440
2-Explorer
hi, am trying to connect to my webserver using IIOT Gateway pulgins Configured as REST SERVER,
Since it was tested using HTTP during testing , it was working fine , While for Production we have to do it in HTTPS.I Am a not able configure it , Support needed.
Thingworx Kepware SERVER EX V6.16.217.0
As iam trying to upload SSL certificate, its showing format error.
''Failed to import the Certificate. the format is in valid''
MKhatri
(To:VS_12009440)
There are many things that could be incorrect with the certificate – some common ones are:
Please go through the article attached for the resolution.
https://www.ptc.com/en/support/article/CS412176
Mohit
Hi @VS_12009440,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
