Our Use Case:
The plc is connected to Scada, and we want to take the data from SCADA to thingworx through Kepware.
1. How can I take the data from SCADA to kepware.
2. What are the provisions to take the data from SCADA to kepware.
Hi, kulkarniew
I found some documentation on how to export data from Eclipse Scada via Modbus TCP, see section 7.4.1. Looks like you would use Modbus TCP in Kepware, to pull this data out. Do you need some help setting up a Modbus TCP, channel and device in the KEPServerEX?
Rob
Thanks for your reply. I need to give this solution to the client, so before that, I must have to understand the whole process. It would be good if you elaborate the process to proceed in terms of steps its great favour for me
Hi @kulkarniew.
If the response from @rsharp-2 answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
