1. Current Situation
CIMON OPC UA Server Information:
KEPServerEX Status:
Other Client Status:
2. Troubleshooting Attempts
Network Connection Check:
Firewall Configuration:
Security and Authentication:
3. Main Issue
The issue does not appear to be related to network connectivity or security/authentication configurations.
While other clients (UaExpert, Node.js-based clients) successfully connect to the CIMON OPC UA Server, only KEPServerEX fails to discover or connect to the server.
4. Environment Details
Hello, Thank you for the detailed description.
Are you encountering any errors while browsing the CIMON OPC UA Server (in manual connection)? Please verify the client-side configuration using the article below.
https://www.ptc.com/en/support/article/CS298913
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
Additionally, I suggest capturing Wireshark packets to identify the issue.
CIMON OPC UA Server Details
UaExpert Connection
Node.js Connection
KEPServerEX Connection
UaExpert Request Packet:
KEPServerEX Request Packet:
TCP Segments Comparison:
Comparison Results:
Network Connection
KEPServerEX Configuration
Wireshark Analysis
Current Situation
UaExpert Connection
Node.js Connection
Wireshark Request Packet Comparison
Comparison Results
Steps Taken to Resolve
Network Connection
Wireshark Analysis
