Hello
I use the driver ControlLogix Ethernet to Write Data to 3 PLC the read function is good but When I am Trying to write Data is very slowly and Take more than 1minute I have switch between Logical and Symbolic but nothing change
Please ensure your project is configured in an optimized way. You can refer to the article below for guidance.
CS292754 - Configuration project performance optimization in PTC Kepware Products
If you believe the project is already optimized, then More information and troubleshooting steps can be found in this article:
CS292760 - Write requests to device fail randomly in PTC Kepware Products
