KEPServerEX license utility
DG_10309508
2-Explorer
Where do you set user name? I can set password.
Check out the Settings — User Manager section of the server help file.
https://www.kepware.com/en-us/products/kepserverex/documents/kepserverex-manual.pdf
Best regards,
Andy Servetas
Principal Technical Support Engineer | Kepware Technologies
Best regards,
Andy Servetas
Your solution worked. Username is "administrator".
