KepServerEx 6.15 antivirus
GV_10694125
3-Newcomer
Hello Team,
I am installing MacAfee virus application in my server, will it affect or malfunction Kepware software v6.15 functionalities?
What steps I need to follow before proceeding to install Antivirus, please suggest.
Ms. Gopi Vanza
@SlidingDownhill, @AS_9408810
The port ranges for the user interfaces are typically user defined.
Runtime Service (server_runtime.exe)
  • Interfaces:
    • OPC DA - 135 plus RPC dynamic port range defined by the OS.
    • OPC UA - user-defined, default 49320
    • OPC XMLDA - user defined.
    • IoT Gateway - user defined per agent configured.
  • All of the Communication Drivers have specific ports defined in each of the Driver's associated Manuals and Help Files.
Here is a link to the my kepware login page where all manuals can be found:
Log In | My Kepware
*Chris
Hello Gopi,
I wanted to let you know that We have sent you a private message regarding your query. Due to security reasons, the details about the port used can't be shared in the community.
If you need any additional support, I would recommend you to open a support ticket. Our team will be more than happy to assist you.
Thank you for your understanding.
Now that answer is troubling - security through (attempted) obscurity is a terrible security model..
I also want to know list of files and folder to be put in white list when McFee antivirus is installed.
  • Interfaces:
Log In | My Kepware
*Chris
I wonder why the first PTC reply said it was some sort of secret?
Thanks Chris
