on the Logix platform, why would @MODE work as a tag but @IsPresent will not pass Syntax check? Both are valid.
(v6.12)
It appears that both are Predefined Term Tags. However, currently, only #MODE is supported by our driver (page=66).
To include the other tag, it requires an enhancement request. Please review the article linked below for guidance on submitting this request to our Product Management team:
https://www.ptc.com/en/support/article/CS295047
If you need to log in to access the full article, please use your MyKepware login credentials. Thanks
