I am using Creo Parametric - Release 7.0 (connected) 7.0 7.0.3.0
I have a round part with a "flow channel" that I am trying to rough out trying to pick mill. My work around is to use 4axis trajectory with full size ball endmills and axis shift tools paths.
Any ideas? I have tried cutline however, Can only get the bottom of the radius pick milled.
Hello @Todd_Reiter
If my understanding of your business need is correct, you need a 5 Axis High Speed Milling (ptc.com) which is:
If you do not have above licenses, and/or no plan to move to Creo 8.0 from a short term perspective, you may consider approaching this with a Swarf Milling sequence:
You can also access an outdated, but nevertheless probably helpful because still effective (still accessing Menu Manager in Creo 7.0) suggested technique on this here.
Serge
Thank you, for the information.
