I can set up a new table add the repeat region and add in the "file path" (no clue what you call it) to each cell. ex. terminal information - mbr.terminal
For the entry ports/pin I found this file path on youtube mbr.connprm.pin.name.
when I first make the harness I designate the connector and assign each entry port a coordinate system to work of off and then add in the entry port when I designate each connector. It also looks like other things aren't working either like if I wanted the wire color or the wire gauge going to the connector.
I know I'm missing something I just can't figure out what.
Hi @AL_13006242
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
