On my manufacturing draws, i have a sheet for each operation (op010, 020, 030 etc.)
On each sheet i have a repeat region with all sequences type, name and tool for the actual operation.
I order to simplify the operatior work, i would like to add a fifth column with the tool_pocket_number for loading the tool carousel on the machine with the right tool.
Here are my column parameters :
When i add &mfg.actoper.workcell.head.tooltbl.toolpocket.tool_position in the fifth column here is what i get :
How can i add for each line the tool pocket number ?
Thanks in advance.
your description is missing an image showing which cell you inserted the &mfg.actoper.workcell.head.tooltbl.toolpocket.tool_position parameter into.
... it would be helpful if you could upload the test data
Hi, on the same line as the other parameters. Line 2 column 5.
try &mfg.actoper.NCSEQ.POCKET_NUMBER
With &mfg.actoper.step.pocket_number it works !
Thanks a lot
Sorry, that doesn't work- try &mfg.actoper.step.pocket_number
