Creo NC work center relation parameters
nlehman
For whatever reason, Creo does not offer the ability to set a default clearance distance per machine.  I do not always remember all the travels on our machines and would like to set default clearance values to solve that issue.
I basically want to set a relation that states:
IF work cell = "insert machine name"
clearance = XX.XX
However to do this, I need to know the parameter names to pull for the work center and the clearance, and I do not know them.  Does anyone know what those parameters are, or know a better way to do this?
30 REPLIES 30
hheinze
11-Garnet
(To:nlehman)
This is the answer to your question directly from PTC.
Answer:
Resolution
  • Not part of the Creo Parametric functionality
    • There is no operation parameter with the name of a Workcell used
https://www.ptc.com/en/support/article/CS133428?source=search&source=copyurl
