GPOST OMIT FEED RATE IN NURBS MODE
Civodul
Why GPOST does not output the feed rate during NURBS machining ?
Attached a new PP completly empty (Postprocessor defaults) and CL file.
CREO 7.0.5.0
GPOST V6.8 P20p2-J11
Regards
Civodul
(To:vnamboodheri)
Here is a answer from an external source:
By default NURBS is not enabled in the Option file, you must set it for your controllers NURBS type.   It shows the screen where you set this in the Option file.  NURBS support in the Option file is limited so you may have better results with the “without_nurbs” output from CREO.
2 REPLIES 2
Hi Civodul,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team
Civodul
(To:vnamboodheri)
