HSM vs Volume Milling cycle time
- April 26, 2025
- 1 reply
- 947 views
Hello Creo Experts, I have a question regarding volume milling. I typically choose volume rough milling sequences for my roughing operations. But now trying to use HSM Milling.. However, I've noticed that the cycle times of HSM sequences are not as efficient as I expected. Despite their name, high-speed milling cycles are actually longer than those of volume milling for the same pocket size. Could you please advise me on any parameters I might be overlooking to achieve a shorter cycle time with HSM or rough sequences compared to volume milling for the same pocket size? Please check the attached MFG file its creo 11 mfg file
Regards, Asif Fisa
