CivodulAnswer
Dec 4, 2023 2:34 PM UTC
Attached an example
Hope this helps
Emeritus
Nov 29, 2023 12:09 PM UTC
Hi ptc-296815,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team
Dec 1, 2023 2:25 AM UTC
This inspection method is not easy to use, no graphics available. I created probing cycles (UDF) using the trajectory function, this method displays the path.
8-Gravel
Dec 4, 2023 7:33 AM UTC
Thank you for the advice.
Is it possible to send me the UDF?
Dec 4, 2023 9:53 AM UTC
It's better to create your own UDF.
You can add your own inspection cycle, PPRINT, PPWORD ...... and customize your post processor.
