Best answer by Civodul
Attached an example
Hope this helps
Community Manager
November 29, 2023
Hi ptc-296815,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Vivek N
Community Moderation Team
This inspection method is not easy to use, no graphics available. I created probing cycles (UDF) using the trajectory function, this method displays the path.
8-Gravel
December 4, 2023
Thank you for the advice.
Is it possible to send me the UDF?
Civodul14-AlexandriteAnswer
Attached an example
Hope this helps
