Hi
i made a postprocessor using GPOST for a double turret, double spindle lathe on Creo 1
The most heavy thing was to force user to insert manual commands on sequences to tell wich spindle to use
In Creo 3 i can define a lathe machine with double spindle and simply choose what i want to use from a dropdown menu
Gpost doesn't manage this information ![]()
How to simplify user life (and why not... my own life programming GPOST)?
Bye
Osvaldo
There are GPOST FIL samples for adding new commands - see link to downloadable samples in this article CS54723
