Manually control direction of B-axis travel
nlehman
I understand that you can set the default direction in the work center, but how do you override the default direction when you need the table to rotate in a specific direction?
For example, my table is set to rotate the shortest direction, but sometimes the shortest direction will cause a crash with the part.  So how do I manually control if the table is going B+ or B-?
Thanks.
nlehman
(To:nlehman)
Manual Table Rotation
So far I have found two solutions to manually control the table, and they both need to be entered into CL DATA under the tool motions tab in a sequence.  The first uses a “rotabl” command, this needs to have a “RAPID” command entered before it, or it will default to having a federate output with it.
*Example
RAPID
ROTABL/ATANGL,90,CCLW
This will output B-90.in the code.  If the RAPID command is not entered, it will output will output "B-90.F10.", there is some default feedrate that it is getting from somewhere.
The other option is a “rotate” command, I am not to sure of the differences.  This command seems to have clockwise and counterclockwise reversed of how you would imagine them to be used.  This is either a post issue on my end, or it is how this command perceives the rotation.  If it thinks that the head is moving instead of the table, then the direction it outputs would be correct.
*Example
ROTATE/BAXIS,ATANGL,90,CLW
This will output B-90. in the code
nlehman
(To:nlehman)
I am able to put "ROTABL/ATANGL,BAXIS,CCLW" into CL COMMAND under tool motions, but it throws in a random feedrate of 10. out of nowhere
nlehman
(To:nlehman)
*Example
RAPID
*Example
nlehman
(To:nlehman)
I had already marked the correct answer, but I have since found that the actual correct answer was to use a "Manual Cycle".  I was not aware of manual cycle and want to document their existence for people that may have a similar question as mine.
The Manual Cycle is located on the Mill tab, and then milling.  Manual cycle is the only tool path for which a tool is optional.
