Mold analysis extension parallel computing
DavorGranic
Anyone know how to enable parallel computing for mold analysis extension?
I get this message when runing analysis:
6 REPLIES 6
You have to run ptcsetup.bat and enable distributed services.
When DS are enabled then you can choose which PC can run analysis
Marco
DS is enabled 😕
In your start menu, under PTC can you find PTC Distributed Services --> Distributed Services Manager ?
Marco
Yeah. I think i found the problem. It says I dont have write permission for cashe directory location so all tasks will fail until changed.
Thanks.
hi
your pudes explain the solution of this problem ?, I'm trying to do some simulations filling and I could not do the test result. only shows me filling the part but does not show me other results such as trapped air, sink marks among others.
