?Pro-NC, 5X OD drill, Mill-Turn, XZC, No Y.
I am drilling the OD of a cylinder. I have a Daewoo Puma Mill-Turn, Fanuc 16T. It is an X,Z,C type setup. My workcell is setup correctly, we've been using this for 7 yrs. The tool axis for these holes is PARLEL X. We are currently using G-post utilizing merged posts, PARLEL X(UNCX01.F02), PARLEL Z(UNCLX01.F12), and a regular turning post(UNCL01.F02). My question:
Pro-e is outputting a RAPID, GOTO/, a CYCLE/DRILL, GOTO/ again and then a CYCLE/OFF for the 1st hole in the ACL file. The susequent holes are output as RAPID, GOTO/, RAPID/, GOTO/, CYCLE/DRILL, GOTO/, CYCLE/OFF. Seems to be an extra RAPID/ and GOTO/ for holes 2-8. I currently have 8 holes programmed. The extra RAPID/ and GOTO/ cause the Retract Cyclinder dimensions to be re-output. This may be causing my issue.?
I've been in the OFG, can't find any settings to change this output. I tried changing the setting on the "Identical Points handling" page under "Motion" -> "General". This did not change ouput. I've been to the parameters page of the machining sequence. The only setting I find is CYCLE_OUTPUT that might influence the output. The 2 options are BY_HOLE or BY_HOLESET. I've tried both, no difference. I even changed the SCAN_TYPE to different setting, no difference either.
I don't know if there's an additional setting in the Plabel file that the under "Advanced" in the OFG that I don't know about. It's manageable, I just edit the NC code, but I don't want to do this. Any ideas or knowledge would be gratefully appreciated.
Do I need to handle all this in the FIL file, search ahead in the ACL file for each additional CYCLE/DRILL and get the endpts and output them? Seems extremely unnecessary.
Thanks in advance for any help,
Jay Crook
