Wanted to check and see if anyone is using the NC Sheet Metal package to program for punching cells? If so, did you change to Pro/NC Sheet Metal from another software and why? Also, anyone have information regarding programming a right-angle shear for the post processor. We extensively use Finn-Power punching cells which has this functionality.
Thanks in advance,
James Little
Corning Cable Systems CAD Admin
