creo manufacturing and Mbd
T_F
I'm starting to learn more about Mbd.
I found this video where shows some relationship between SOLIDWORKS and Cam works.
https://youtu.be/aw9ntdXpbbY
I would like to find some information regarding CREO manufacturing and Mbd. Any suggestion?
VladimirN
(To:T_F)
"Creo Parametric - Model Based Definition (MBD) Overview": https://www.youtube.com/watch?v=skRxJvPgmMU
"Creo Parametric - Model Based Definition (MBD) - Creating Dimensions [Tutorial]": https://www.youtube.com/watch?v=s5r77skVjm4
More here: https://www.youtube.com/c/CreoParametric/search?query=MBD
This Creo Parametric lecture video explains the background of Model Based Definition (MBD), common objections and concerns, and the basics of implementing and using it. For more information, visit https://www.creowindchill.com. If you learned something from this video, please give it a thumbs up ...
This Creo Parametric tutorial video shows you how to create dimensions manually as Annotations as part of the Model Based Definition process. It shows how to create an Annotation Plane, change orientation, and define a dimension using edge or surface references. In addition it covers: * ...
VladimirN
(To:T_F)
T_F
(To:VladimirN)
I does it have any relation with CREO manufacturing. Basically, does CREO manufacturing changes it's approach to machining according to the tolerance applied to a hole?
