keeping the tool down
dfarneth
Hi All,
I've had this situation before but I just lived with it. But I'm tired
of it and would like a fix. I use profile sequences a lot and at the end
of a pass the tool always retracts and comes back down. Can anybody tell
me how to keep the tool down in between cuts? I will attach a picture of
the tool path.
Don Farneth
Engineering Associate
COORStEK
North Table Mtn.
Golden, CO.
303-277-4686
5 REPLIES 5
Hi Don,
We also used to experience such problems.. looks like the are inherent of Profile Sequences... so I avoid using them in toolpaths where the problem may arise...
What I do to get rid of this problem is to use Trajectory Milling Sequences with the option CONNECTION_TYPE set as Z_LAST, as you can see in the attached screenshot. Works like a charm!
HTH
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
Don,
One thing that I have done as a work around with ?Profile? is to lower the
retract plane to the same height as the cut. Then in the customize box I
would add a GoDelta to retract at the end. I have tried to get PTC to get
rid of all the automatic retracts with no luck.
Kent
Kent Hanson
Chief Executive Officer
27011 Washington Blvd
Edwardsburg, MI 49112, USA
T 269.663.5515
<">http://post-pro.com/default.aspx> khanson@post-pro.com
<">http://postpro.web.officelive.com/default.aspx>
_____
Hi All,
Thanks for all the great replies!
I got just what I wanted by using the Custom Trajectory sequence with
parameters.
1.Conection_Type = Simultaneous
2. Cut_Type = Zig_Zag
3. End_Motion = Z_Last
4. Slice_Path_Scan = Slice_By_Slice
I had never used Custom Trajectory like that before.
It never fails when I get stuck with something this community comes
through!
Thanks again for all your ideas.
Don
A couple more things when using that sequence and those parameter. I like to use "Simultaneous" for the CONNECTION_TYPE so the tool ramps down. If your TRAVERSE_FEED is set to "-" you may get unwanted rapid moves. At least it is this way in WF4 build M070 and has been for a long time.
Terry.
Glad it worked for you Don, 😉
