Hello
I am trying to use family table for manufacturing file. I would like to add different name for the machining operation when you activate an instance. For example, is it possible to add a global parameter named NUM_OP which is different for each instance (please look at the attached picture) and to add a relation to automatically rename the machining operation? Or is there another solution to realize this?
Many thanks for your help.
Guillaume
Hello Guillaume, I'm trying to do the same thing. Have you found a solution ?
On peut parler en français si plus simple pour vous. ![]()
Bonjour
Je pense que je vais continuer en anglais pour obtenir un maximum de réponse.
No I didn't find solution for tis issue. But, to be honnest this project has been stopped for the moment and i didn't spend time to find a solution. I think, I will need to use a .bat file during the post-process to be able to put the name of opération I need.
Sorry not to be able to give you more details.
A+
