Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Since you can't mold perfect parts every time, you need to reference the standards to properly account for tolerances. In the mean time, this should get you started. Good luck!
