I am using Mathcad Prime 6.0 6.0.0.0
Dear Support,
I have downloaded the C# WPF project for using the API Mathcad (https://support.ptc.com/help/mathcad/r7.0/en/index.html#page/PTC_Mathcad_Help%2Fexample-2_ms_dev_studio.html%23) but it does not work (Problem to connect Mathcad Prime).
I'm using Prime 6.0.
Is this version compatible with your API ?
Irénée
Here are the errors that I faced
ex.Message = "Retrieving the COM class factory for component with CLSID {A00E8B95-D415-433F-A04E-D298A54A7BB7} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))."
Irénée,
Try to test this on Mathcad Prime 7.0 version:
https://www.mathcad.com/en/try-and-buy/mathcad-express-free-download/install
Hi Irénée,
1. Submit your issue here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
2. Read this article - "How to solve COM Exception Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))?": https://stackoverflow.com/questions/1496214/how-to-solve-com-exception-class-not-registered-exception-from-hresult-0x80040
Thanks for the answer Vladimir.
I tried to change the target platform "x86", "x64", "Any CPU", without success.
The problem occurs when I want to start Mathcad (error during the instanciation "_mathcadPrimeApplication = new Ptc.MathcadPrime.Automation.ApplicationCreator();")
Irénée
Hello Vladimir,
I have the same error message.
In the source code, we have two ways for launching Mathcad Prime:
The active way is by using constructor. By this way I have the error message during the instantiation.
The other way is to using Activator (needs to uncomment the following lines):
Type typeofOpPrimeserver = Type.GetTypeFromProgID("MathcadPrime.Application");
_mathcadPrimeApplication = Activator.CreateInstance(typeofOpPrimeserver) as IMathcadPrimeApplication3;
By trying this other way, I retrieve a null type for typeofOpPrimeserver. I tried with another prog ID as "MathcadPrime.Application", but the type is always null.
By curiosity, I tried with just "Mathcad.Application" as prog ID, and in this case the type is not null. But the following code does not work, probably we need to launch MathcadPrime, not Mathcad.
Irénée
Irénée,
Vladimir, I confirm that it works with Mathcad Prime 7.0.
Thanks.
Happy new year,
Irénée
I'm glad you solved your problem!
This really is a poor answer, for those who have not yet upgraded to version 7.0.
Are there any valid answers that do not include purchasing an entirely new version of Mathcad??
