I have been using Mathcad 14 for many years. After upgrading to a new PC, I tried to reinstall Mathcad 14, but the licensing process failed. The website returned the following message:
The remote server returned an error: 403 Forbidden.
Could you please assist me in resolving this issue?
Support for Mathcad (all versions) and Prime (up to and including version 6) ended a couple of years ago, see here.
For licensing you need to contact PTC support directly, as this forum is for and (mostly) by users of the software.
To reach PTC support try the following links:
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
How did you bypass the Website? I've got the exact same problem and I'm getting zero help from PTC.
That link gets a new license, which installs flawlessly, and says it is valid, but the first time you try running Mathcad, it says it is invalid and you are back to the beginning without a working license.
