Failed to obtain free 30-days trial license for Prime 7.0.0.0 because of -103 error
LP_9956387
2-Guest
I am having a license request failure when trying to get a 30 days free trial for PTC Mathcad Prime 7.0.0.0
@LP_9956387,
If node-lock license is configured, PTC flex-enabled application cannot be accessed via Remote Desktop session or Terminal Services connection
Please refer Error: "Terminal Server Remote Client Not Allowed" or "(-103)". for more information
Hope this helps
Vipul
6 REPLIES 6
LucMeekes
(To:LP_9956387)
Did you check here for a possible solution to your problem?
I did this but still the same error. Here's the error I am getting. "(-103) Cannot checkout an uncounted license within a Windows Terminal Services guest session."
Hello @LP_9956387,
What is the error message that you are receiving?
It would be great if you can attach the screenshot of the error message
Vipul
Got this error "The license request failed." and "(-103) Cannot checkout an uncounted license within a Windows Terminal Services guest session."
@LP_9956387,
Hope this helps
Vipul
that explains everything. Thanks for this solution!
